Andrew736
Posté le: 10 Sep 2026 09:50 Sujet du message: U4GM Monopoly GO ACME Kaboom Event Guide |
ACME Kaboom gives Monopoly GO players a short, two-day reason to keep circling the board. It runs from September 9, 2026, at 1 PM ET until September 11 at 1 PM ET, so there is not much room to leave it for later. If you are already keeping an eye on a Monopoly Go Partners Event, this solo event can fit nicely into the same play session. The big draw is the reward pool: up to 18,165 Dice Rolls, 133 Adventure Club tokens, sticker packs, cash, and several timed boosts.
Corner tiles drive the score
This one is all about the four corner spaces. Every time your token lands on a corner, you receive four points multiplied by the Dice setting used for that roll. At x10, that is 40 points. At x50, it becomes 200. It sounds simple, but the corners are far apart, and that can make high settings feel rough when the board is not playing along. Most players will find that a medium setting gives them a better shot at making steady progress without draining their roll supply in a hurry.
Use Go to Jail with some care
Go to Jail is usually the corner worth watching most closely. It is a scoring space, and it also opens the Jail mini-game. A doubles result may return extra Dice Rolls, based on the number rolled and the setting you chose. A double six at x100, for instance, can award 600 Dice Rolls. That is a nice hit, though it is not something to chase every time. A practical routine looks like this.
Use Auto Roll when you just want regular movement around the board.
Raise the setting only when Go to Jail is within a realistic range.
Drop back down after several missed attempts.
Save a few rolls for other live activities and daily tasks.
Rewards build from small pickups
The early milestones move quickly. The first 15 points provide 25 Dice Rolls and nine Adventure Club tokens, while the first sticker pack arrives at 65 total points. Later targets ask a lot more. Milestone 15 offers 375 Dice at 1,300 points, milestone 25 gives 925 Dice at 4,400 points, and milestone 43 brings 1,400 Dice at 15,475 points. The last milestone is a serious stretch: 51,625 total points for 5,000 Dice Rolls. It is fine to set a personal stopping point rather than forcing the whole track.
Make each session count
There is no need to stare at every roll. Let Auto Roll handle the quieter stretches, then pay closer attention when your position makes a corner landing plausible. Timed prizes such as Builder's Bash, Cash Boost, Color Wheel Boost, and Mega Heist are more useful when you can stay in the game and use them straight away. Players comparing options like Monopoly Go Partners Event for sale may also want to keep their Dice budget flexible, since ACME Kaboom rewards patience more than wild swings. |
