Andrew736
Posté le: 10 Sep 2026 09:37 Sujet du message: U4GM Guide to COD MW4 Inner Circuit M4 Redemption |
Digital pre-orders for Call of Duty: Modern Warfare 4 come with a day-one weapon option: the Inner Circuit M4 Assault Rifle Blueprint. The game is due to arrive worldwide on October 23, 2026, and anyone weighing up Modern Warfare 4 Boosting alongside their early purchase will want to know that the blueprint is tied to a digital edition only. Pick it up before launch, and the full M4 build is waiting from the moment you load in. Retail disc copies are not included in this offer.
One Build, Two Looks
The attachments and weapon performance stay exactly the same across every system. What changes is the finish players see. Xbox Series X and Series S owners receive the Xbox 25th-anniversary treatment, called OG Green. It is transparent, bright, and clearly inspired by old-school see-through hardware. You can spot internal parts through the body of the rifle, plus small controller-button details on the receiver. On PlayStation 5, Steam, Battle.net, Nintendo Switch 2, and Xbox on PC, the same blueprint appears as the Mil-Spec version instead. That one uses a brown-and-red transparent look, which feels more grounded.
What Each Screen Shows
Where you play Inner Circuit appearance
Xbox Series X or Series S OG Green anniversary finish
PS5, PC, Switch 2 Mil-Spec brown-and-red finish
There is a small twist in multiplayer. The appearance is decided by the system running the game, not by who originally owned the dropped weapon. So, if an Xbox player leaves an OG Green M4 on the ground and a PS5 player grabs it, the PS5 player sees Mil-Spec. You cannot switch between the two styles in the menu. The green version is visible only while playing on an Xbox Series X or S console. Players have until October 23, 2027, to claim the reward.
Built for Fast Fights
11.5-inch Shortline Barrel for quicker handling.
ZLR ASP50 Stock to keep movement snappy.
FTAC Dominion Muzzle to settle recoil.
FSS Fireline Grip for a steadier hold.
SZ Prima-4 Dot Optic for a clean sight picture.
This setup is aimed at players who like moving through tight lanes rather than sitting back at long distance. The short barrel and retractable stock make the rifle feel lighter, while the muzzle and grip help keep bursts under control. It will lose some confidence across very long sightlines, sure, but in mid-range fights it should be easy to pick up and use without much fuss.
Double XP Details
Promotional Double XP tokens are also set to carry value in regular Multiplayer, then Warzone once Season 1 begins. DMZ is currently listed as outside the offer, so it is worth checking the token wording before saving them for a specific mode. For players planning their first few sessions, cheap Modern Warfare 4 Boosting may be part of the conversation, but the Inner Circuit itself is simply a pre-order cosmetic build with a clear close-range purpose. |
