Andrew736
Posté le: 10 Sep 2026 09:26 Sujet du message: How to Farm Diablo 4 Mythics with U4GM |
Kurast Undercity in Season 14 is less about clearing every room and more about making quick decisions under pressure. If you want a steady route toward stronger D4 items, this place can be worth far more than a casual dungeon run. The clock changes everything. You'll spot routes you'd normally ignore, leave stragglers behind, and chase the map markers that actually move your reward meter. A build with fast movement, wide attacks, and little downtime feels much better here than a slow boss-focused setup. Don't wait for a perfect run, either. Learn the layout rhythm, keep moving, and the results start stacking up.
Play the Timer, Not the Whole Map
The most common mistake is treating the Undercity like a standard dungeon. It isn't. Your real target is reward progress before time runs out. Beacons and dense enemy groups should pull you off the main path when they're close, since both can push the meter forward quickly. Hourglass-marked enemies matter even more. They buy time, and that extra time can turn a rough run into a high-rank clear. When you enter a new section, give yourself a second to read the markers rather than charging blindly.
Take nearby hourglass enemies first when the timer is tight.
Light beacons that don't drag you far off your route.
Choose packed monster groups over scattered targets.
Skip dead ends unless they hold a useful objective.
Watch for the Portal Prankster
The Portal Prankster is the kind of surprise that makes players change plans on the spot. If this rare goblin shows up, it's usually worth dropping what you're doing and bringing it down fast. The fight itself isn't the point. Its value comes afterward, when extra reward chests appear following the district boss. That can mean more crafting materials, more high-level drops, and a much better payoff for the same entry cost. You won't see it every run, so there's no point building your whole route around it. Still, when it appears, don't let it wander off while you're busy clearing ordinary packs.
Set Up Each Run With Purpose
Before stepping through the entrance, use the Spirit Brazier with a clear goal in mind. Tributes shape the run's difficulty and reward category, while Bargains let you spend Obols to narrow the kind of gear you're chasing. That little bit of planning saves plenty of wasted runs later. Pair your choices with a build that can travel quickly, then use hourglass targets and the Portal Prankster whenever they appear. Players looking through D4 items for sale can also get a clearer sense of which slots need attention, then aim their Undercity rewards toward those upgrades. |
